      PN for tko 600...
      i am looking for a PN for a plug that i can use for by reverse light switch on a TKO 600. thanks
      wow, all these views and nobdy, o well i will take a trip to the store and see what they have
      Encinitas, CA
      I have searched high and low for a pre-made plug for the reverse light switch and I have not found one.
      I tried Ford, auto electric specialists, terminal supply company's and have had no luck.
      I used a plug taken from the wiring harness of a junked 1990 Mustang (with manual transmission) and it snapped right into place. You can read my install write up to see how I handled this connection: http://www.classicchevy5speed.com/tr..._camaro_wu.htm.
      I hope this helps. Sorry I did not respond sooner.
      Jeff Mortenson
      ok, i had seen that but thought there was a PN for that plug. you wouldnt happen to know what that plug was for on the mustang would you?
      Encinitas, CA
      The plug on the Mustang was used for the same switch - the reverse light switch on the Mustang's transmssion.
      I cheked with Ford and showed to Ford part's guy's the plug and they both said that i would need to buy th eenitire wiring harness to get that plug - it is not sold as a sepearte item. If you find out differently let me know.
      Jeff Mortenson
      ok, thanks. i will try anyways, if not i will take a trip to a local junk yard
