Thread: LS1 Rear brake problems
- Oct 2005
- 2
When putting my rear brake setup on my 68 Camaro's factory 10-bolt. I ran into a problem with the rotor hitting the out side of the caliper basket (seen in the picture attached). It could be fixed by spacing the backing plate out from the axle flange but is this something people usually run into while doing this swap. By the way you guys talk everything just slides on. Thanks for your help.
05-09-2006 #2
- Jan 2005
- 3
LS1 Rear brake spacing
I did this swap and did have to pull the axles and make approximately a 3/16" spacer for the backing plate. This spaced the basket out enough to get the right clearances for the rotor.
Noel
05-09-2006 #3
- Mar 2005
- Colorado
- 94
What did you make the spacer out of? I am having this same problem.
68 Camaro
LS2 6speed
Complete Hotchkis front and rear suspension, Global west SFC, 3rd gen steering box, C5 front rear discs w/ 4th gen booster and MC. 8.5" posi rearend with 30 Spline 12 bolt axles.
05-10-2006 #4
- Nov 2004
- Colorado
- 1,260
