      Del-a-lum Bushings Question
      I ordered DSE upper/lower control arms with del-a-lum all around bushings. For the rear springs (3" DSE leaf springs) shackles should I go with del-a-lum bushings as well or with the DSE Urethane bushings/ rubber for the front of the leafsprings(thats how DSE sent them) work fine?? Car is for street/strip use. -chris
      Oct 2003
      Arvada, Co
      I would go with del-a-lum for the rear eye atleast.
      Brian
      Sep 2002
      San Jose, CA
      Keep the rubber bushing in the front spring eye. If you use a Poly or solid bushing it will create bind in the suspension
      Just call me Brett
