Results 1 to 20 of 45
Thread: E - 85
05-05-2006 #1
New to Pro-Touring
- Apr 2006
- 52
E - 85
Anyone running E - 85 in their carb. higher comp. motors? I think this stuff is 100 octane, but not sure how it would work? Just a thought...
05-05-2006 #2
Starting The Transformation
- Oct 2005
- SoCal
- 489
Going to do some testing with it shortly, but from what I have seen it works great. Need to run the car a bit richer than with regular pump fuel but no real down sides. And yes you can run higher compression and/or a lot more boost with no adverse effects.
05-06-2006 #3
New to Pro-Touring
- Apr 2006
- 52
cool....I figured a jet change, any spark plug changes I wonder??
05-06-2006 #4your fuel systerem has to be alcohol compatable including lines, fittings and the needle/seats in the carb. i have also read that the needle/seat neds to be larger which all alcohol ones are.
05-06-2006 #5
- Oct 2005
- SoCal
- 489
no no NO NO NO IT DOES NOT!!! I don't know where you guys are getting this misinformation but you could not be more wrong. It's ETHANOL, NOT METHANOL. They are VERY different, methanol is highly corrosive and requires all the special stuff. An 85% ethanol mix will be just fine on stock fuel system components, as has been proven by people running it for quite some time now.
Originally Posted by homerneedspeed
Yes you need to rejet the car but not to rull meth specs.
Please people, do a little research before you stick your foot in your mouth.
05-07-2006 #6
- Apr 2005
- 79
05-07-2006 #7
