      Houston, TX
      LS1/LS2 heater connections
      The LS1/LS2 has the "In" and the "Out" side by side. I am connect a Vintage Air system to an LS2. Which port is "In"? Which is "Out".
      I would assume the one closer to the front of the motor is for coolant to return from the heater. The port closer to the rear of the motor is the supply line for the heater (before the thermostate).
      Please confirm.
      Phillip
      The bigger is out and the smaller is in.
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
