      Coilover 4Link in a 1992 GMC Typhoon - Need Help
      Is there enough room in front of the gas tank to fit the support crossbar that the top of the shocks and the panhard bar attach to or do I need to install a different gas tank? It's tight up in there and I was wondering if any of you have successfully done this install on a 1st gen (1982-1994) S-series Blazer. This problem is a non-issue on pickups since the gas tank is in a totally different location. The truck is up on the installer's lift and I need help real quick. The 4link kit I am trying to install is off of a wrecked Typhoon but I can't get in touch with the prior owner. It was made by PEP.
      Feb 2006
      Hello, I'm also a Typhoon owner, you should check out www.syty.net, I think the 4link has been done before. Hope this helps.
      Greets,
      Arlo
