    Results 1 to 10 of 10
      New Jersey
      Detroit Speed 3 Inch Dropped Springs
      i was just looking at my traction bars realizing how ugly they were when a thought popped back into my head. Someone asked me why i had the bars with my dropped springs. That person was under the impression you didnt need traction bars with those springs. Is this true? If i take my traction bars off will the new springs prevent wheel hop in any way?
      1969 Camaro SS aka Jumpin Jack Flash
      World All Aluminum 427 and tko-600 attached to that
      http://www.cardomain.com/ride/2305230/1
      Chandler, AZ
      Springs
      I talked to Stacy @ Detroit Speed a couple months back about the springs and was told they were designed to minimize and help eliminate wheel hop. She also stated that with the right conditions, combination of traction and different types of pavement surfaces that wheel hop could still happen, but for most of my use they are working out fine.
      zachary louisiana
      if dse are similar to hotchkis then i didnt need them....i had traction bars with my stock springs b/c i needed them bad...then when i went with hotchkis i figured i try without them b/c they look bad....and it was better than with them on...no wheel hop at all..
      1969 camaro ss 372,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......99 console with megashifter, ls1 brakes and a soon to be 700r-4
      http://http://www.cardomain.com/ride/2246580
      New Jersey
      sweetness....but how could u have less wheel hop with the traction bars off?
      zachary louisiana
      when they were on i still had a little bit of vibration...i think it was b/c i had the el cheapo ones you get at autozone for 50 and they werent set up for my car so they didnt work as well as they should...and when i swapped to the hotchkis all wheel hop at launch went away
      Chandler, AZ
      Detroit speed has a different design rather than your traditional factory style. Along with the drop thay have an engineered the spring to provide support toward the front spring eye that should limit the need for a traction device.
      New Jersey
      beautiful.....those come off. one more question on the wrong thread but i got the frame conectors but im going to bolt them in......does that help much if they arent welded?
      westchester county new york
      I would think the bolt ins are an improvement but not quite as effective as the weld ins.
      New Jersey
      thats what i thought im not sure the are worth it though
      New Jersey
      van u got any pics of your car?
