    Thread: HSR Distributor
      HSR Distributor
      What are my options for distributors if I want to use computer controlled timing with the Holley Stealth Ram? Is there an HEI unit that is out there that will fit, or do I need to do something else? I do need a small cap distributor with the HSR, correct, or would something like the MSD-8366 fit?
      Dan
      Dwalk47,
      A small cap HEI from the late eighties to early nineties works well, I believe it needs a Holley wiring adapter, PN 534-138. The MSD also works with the above adapter.
      For more info on Holley EFI, I recommend you check out the EFI section of the www.chevytalk.com Forum. DougF, an engineer involved with Holley's EFI program, is the moderator of this section and often answers posts.
      John
