Results 1 to 10 of 10
Thread: New Member in NW Houston
New to Pro-Touring
- Jan 2005
- Houston, TX
- 5
Hello everyone - I've checked out the site before but spent most of my time on Camaros.net. I'm almost done, it that ever really happens, with my 67 Camaro. - My version of a G - Machine
I've been to the Spring Cypress street meet a couple of times on Saturday and plan on being there most Saturdays this summer. Ask me if you don't know. 350 cars and it's free!!!
Below is my build sheet - I just cut and pasted anyway I'm trying to finish up a console/trunk and headliner and should be ready for summer. Have any questions about anything I've done? Fire away.
I love this site and what I see so I know I'll be asking my own.
- 383 Stroker
- Edelbrock Air Gap port & polish match with heads
- Barry Grant Speed Demon 750 electric choke VS
- Vintage Air Frontrunner Serpentine belt drive system
- Edlebrock Performer Aluminum heads 2.02 Full street port/polish
- Keith Black 10.3 – Pistions
- Comp Cam 280H Duration at .050 – 231
- Hardened comp cams push rods
- All ARP bolts
Exhaust
- Flowtech hot jet coated 1 5/8 inch full length headers
- 3 inch mandrell bent with Flowmaster 40 series
Transmission
- Tremec TKO 500
- Centerforce Dual friction clutch/pressure plate
- Centerforce bell housing
Rear End
- 8.5 inch ten bolt posi built by Pyle Brothers
- Eaton posi 3.55 gear
- Superior Axels
Suspension
- Global West tubular upper & lower control arms with del a lum bushings
- QA1 single adjust coil over shocks
- Hotchkiss rear lowering (1 ½ inch) leaf springs
- Poly urethane bushings all around including motor and transmission mounts
- 2 inch Superior drop spindles
Steering
- Detroit Speed & Engineering quick ratio power steering gearbox
- Tilt Column
Cooling
- Be cool polished aluminum radiator
- Spall 14 inch electric fan
- Stewart high flow T-Stat
AC/Heat
- Vintage air Gen II heat and cool
Brakes
- Baer Brakes – Front Track system 13 inch slotted/cross drilled, zinc washed rotor, 4 piston calipers. Rear – Touring system 12 inch slotted/cross drilled, zinc washed rotor, 1 piston calipers
- Stainless and or braided stainless lines throughout
Wheels
- Budnik Hammer Brushed center, polished hoop, soft lip
- Front – 18 X 8 with 4.75 back spacing
- Rear – 18 X 9 with 5.375 back spacing
Tires
- Nitto 555 Extreme
- Front – 235/40/18
- Rear – 275/40/18
Electronics
- Painless wiring complete 18 block wiring harness
- Auto meter gauges
Ignition
- MSD 6 Ignition
- MSD Pro billet distributor
- MSD 8.5 mm plug wires
Stereo
- Alpine 9835 receiver, CD/MP3/WMA, electronic crossover, 3, 4 volt outputs, 7 band equalizer,
- Polk Audio Momo series C500.1 Mono block amplifier 350 X 1 @ 4 ohms
- Polk Audio Momo series C400.4 amplifier 100 watts x 4 @ 4 ohms
- Pair Rockford Fosgate T2 10 inch subwoofers in sealed Q logic box
- 2 Pair Polk Audio MMC650 6.5 Inch co axial with external crossovers
Hello tunnell, is that light?
http://groups.msn.com/1967CamaroSS/_...pgmarket=en-us
