    Results 1 to 15 of 15
      Oct 2005
      SoCal
      Lets talk turbo voodoo
      Not any build in particular, but theories and practical application in regards to hot side plumbing. With as many turbo PT cars being built maybe we can all learn a thing or two. If you have any experience on the subject please speak up *cough* Tom Nelson *cough*
      As well all know there are two basic directions you can go. Either a nice merge collector, somewhat equal length tubes, a more traditional header type configuration. The other being a simple log, many times just using a stock exhaust manifold.
      I've seen both designs make phenominal power in various cars, and often times the same shop using both styles in various builds. W2W for example, built a beautiful 4:1 merge collector setup for the MULE, but used stock manifolds on a 1400hp corvette. As well there are quite a few crazy powerful TT vipers using stock manifolds.
      So what do YOU think is the ideal setup? and why? If you have any hard facts please share with the rest of us. I've talked with quite a few well known engine builders and recieved a different answer from every single one.
      note: My friend and I are working on a back to back test with a few designs to see exactly what changes so hopefully there will be some 1st hand hard data fairly soon. We have come up with a pretty extensive and educated hypothesis which I will post shortly, but it wouldn't be the first time guesses (even good ones) have been way off.
      And yes it is dangerous when a couple engineers are bored and start brainstorming
