      MD
      I need some help on this one...
      This is a problem that has been haunting me for quite some time now...
      Background: 350 GMPP crate motor, bone stock except for a 454/454 lift, 265 advertised durration cam. Performer RPM Q-jet intake, Edelbrock Performer carb, PN 1406. Accel vac/mech advance distributor, no computer. Stock fuel pump. Edelbrock TES headers, the #6 primary is kinda banged up from the control arm... probably enough to affect performance, but I cant see it causing the following problem...
      Symptomes: Launching in 1st gear, at around 4,000 RPM, the car kinda stumbles. The motor sounds fine (other than the fact that it is not climbing in RPM) and it pulls again after about half a second of this BS all the way to red line.
      It doesnt do this in any other gear, under any circumstances... from a roll or once into second/third/fourth after launching from a dig.
      Last night, I noticed that the wire supplying power to my coil was not able to trigger my relay that I was setting up for my electric fans. Should it be able to? The relay is definately good, because I ended up wiring it to my fuse box and it works fine.
      I have tried playing with the timing, adjusting the carburetor (although it has not been opened up to swap rods or jets), and changing the accelerator pump settings (for a different problem). Nothing has helped... it feels like its a flat spot.
      What do you guys think it could be?
      Arlington,TX
      What about the fuel filter, how old is it?
      MD
      Not too old, and its glass (I know, I need to get rid of it) but it looks clean enough.
      MD
      I noticed something else yesterday... it doesnt do this if you dont get into the secondaries.
      Any ideas?
