Thread: LQ9 Options
04-22-2006 #1
LQ9 Options
There arent a lot of LSx engines going cheap in the UK, and when I found an LQ9 on ebay for not a lot of money I bought it. I've got 3 LT1's, and now I've got an LQ9 that I cant swap stuff into
Right so what year auto gearboxes can I use on this? I have a '95 4L60E sat spare, along with a 4L80E. Can you only use the late split bellhousing ones with these? I was planning on running a factory PCM, but open to suggestions.
04-22-2006 #2Yes, you can bolt up the trans to your ls1, but one belhousing bolt will not be used, so only 5 will be holding the trans on. No big deal. I have almost 1000 hp and mine is still holding on strong! You can use any auto gear box.
Twin Turbo Ls1 '71 Chevelle
93 octane 1000 hp street car!!
04-22-2006 #3
- Sep 2005
- Orlando
- 296
Any year trans will bolt up, but the flexplates and torque converters are all different.
I was under the impression that the 98-up 4L60E was the only one that would work with the factory LS1 PCM. I may be wrong though. I know you can bolt up any older non computer controlled trans, like a 700R4, TH350, TH400, P-Glide, by using 5 of the 6 mounting holes, and using the correct flexplate.,Chris
67 Camaro single turbo LSX/T56 -V2.0 underway
06 AMG CLS55 2.9 Whipple, 5.6 forged Darton MID
06 AMG E55 w 63 conversion 2.9 Whipple
99 FRC Corvette pretty in pink
04-22-2006 #4I realised they would all fit physically, it was if I could use a stock PCM and one of the boxes I already had?
