    Thread: Goodwrench?
      Goodwrench?
      How much HP can you get from a Goodwrench Sbc engine block before it blows?
      I`ve heard a lot about the mex made blocks but are the rumours true?
      All under 6.27 litres is a starter.
      Colorado
      What have you heard about the Mex. made blocks. Good or bad? I have one that was Hecho en Mexico. Would like to know myself.
      Dec 2002
      Lost Wages, Nevada
      I had one Hencho en Mexico that lasted 247,000+ miles before a rod cap failure..... (I actually suspect the rod bolt.)
      I ran that thing hot/cold to the redline every gear until I got into the binders.... everytime the engine started. I dropped a set of TFS 23* heads on it with a small flat tappet cam and it made 418-ish hp on 87 octane. It was pretty much the same build that the magazines did multiple articles on in the early 2000/2001 issues.
      Back then (circa 1990) it was $1199.00 and rated at 250hp with a small carb, an after market manifold and headers. If you pick the right parts I can personally spot you at getting 450hp out of it, normally asperated.
      Mar 2002
      Redwood City, CA
      I've heard the bad rumors. They're not true. One rumor that might be true is that the block is actually better than your stock block. It supposedly carries more nickel in it. Most are 4 bolt mains with cast crank, rods, and pistons. They should be good for between 450-500 hp with all the right parts. The one downfall is that most are limited to 8.5:1 compression. It takes a damn small chamber and shim head gasket to get over 9.6:1. They are good engines, despite what some people say. They are an excellent base for a street motor.
      Allen Ortega
      The block i got is empty one from Target/Goodwrench that will be an 383 when it`s finished.
      So you all think that it will work?
      Colorado
      Quote Originally Posted by zbugger
      I have heard this about Mex. Ford blocks.(more useless info taking up limited memory space ) I just haven't heard anything until now about Mex. Chevy blocks.
      Southern California / Maryland
      Been running one in my Brother's 66 Chevelle for about 3 years now with NO problems at all
      Mar 2002
      Redwood City, CA
      Quote Originally Posted by 383
      It should work plenty well.
      Allen Ortega
