      Feb 2006
      Southeast Louisiana
      Double Hump Heads Question
      Does anyone know if a double hump head can be drilled and tapped to accept an alternator bracket that mounts to the head and water pump? I currently have one of those nasty long skinny brackets that is impossible to line up correctly. I've been told that you can't drill and tap them because of the water jackets. Does anyone know?
      Sep 2002
      San Jose, CA
      You run the risk of going into the water jacket if you tap them.
      Are you running a long or short waterpump?
      Just call me Brett
      Feb 2006
      Southeast Louisiana
      I'm running the long water pump.
      Sep 2002
      San Jose, CA
      I've gotta bust out my favorite discovery in the hot rod world again
      http://alangrovecomponents.com/S.B.Long_Pump.htm
      You need
      PN 215RO
      and
      215R - ALT.
      $75 and the problem is solved
      You're welcome
      Just call me Brett
      Feb 2006
      Southeast Louisiana
      You are the man! Thanks for your help.
      Aug 2003
      I have drilled them
      Feb 2006
      Southeast Louisiana
      Thanks for all the info. This is just a temporary fix until I get the 489 BBC built! I'm definitely going with the March serpentine system on the next motor...no matter what the cost.
      Chris
