    Results 1 to 9 of 9
      Nov 2004
      Pickering,Canada
      LS1 front and rear brake conversion help
      guys what does it take to install 2000 camaro SS front brakes on my 69 camaro?? As well as rears.please let me know what I will need.I have all calipers,rotors,spindles,baskets and parking brake set ups.thank you in advance.
      Steve
      zachary louisiana
      i have not done the rear yet but the front was cake.....get the right bolts...mount the special ls1 brake braket to the spindle, which might need to be milled donw to be flush, mine did....get some one to turn donw the od on the hub to acomodate the ls1 rotor...press out the old wheel studs and get new longer ones about 2 1/4"....mount the caliper braket to the ls1 braket then the caliper..get the right lines and your set...short version....
      1969 camaro ss 372,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......99 console with megashifter, ls1 brakes and a soon to be 700r-4
      http://http://www.cardomain.com/ride/2246580
      Charlotte, North Carolina
      69 LS1 Calipers
      I've installed them on my 69. Their is one additional modification to the front spindles that is required....you need to shave off approximately 1/8" of metal off the top boss area so the calipers will line up correctly.
      I'm got a problem with the rear caliper on the driver side which I just noticed yesterday while under the car. The caliper position (mounted on the back side of the axle)interfears with the position of the stock shock location. I've been told that I need two right side calipers so I can rotate it to the front of the axle therefore allowing the mounting of the shock in the stock position....(picture attached of rear mounting caliper)
      You'll also have fun matching the bubble flair metric brake lines with the stock double flair fittings!
      Chuck
      St. JACOB ILLINOIS (ST LOUIS AREA)
      brakes
      doing the fronts here real soon myself looking for drum spindles if antone has some. also looking for the rear backing plates off a ls1 rearend if anyone has them thanks guys Scott
      zachary louisiana
      ls1tech.com has a ton of them look there and ls1.com or there is always ebay. i got mine loaded with pads from napa for 57 apeice for the front calipers and got the brakets from a junk yard
      Huntington Beach, CA
      So to do the front brake conversion you need the drum spindles? I take it that means the disk spindles don't work?
      I've done some forum searches and seen some information on the ls1 swap however is there a step by step guide that anyone has put together? Maybe with specific part numbers as applicable?
      zachary louisiana
      you can use either spindle is is just the top boss will need to be machined...the drum spindle takes way less machinery..this means when you buy the cnc braket for this swap where it bolts to the spindle...the lower bolts to the steering arm....the upper bolts to the spindle (on the drum it is the huge threaded hole wehre the springs are attahced to ..mine didnt need but a tiny bit to get the braket flush.....
      you only need a few things
      spindle and drum hub (which needs to be machined)
      98+ ls1 caliper and caliper braket
      longer studs
      brake lines and cnc braket
      rotors and pads and some bolts
      then use stock bearings i am almost done with mine and hope to get it onthe road soon
      there is some part #'s on this site
      http://www.pozziracing.com/12_corvet...es_on_fgen.htm
      Excellent link!!
      Thanks!
      Now to decide if it's worth replacing brand new factory disk brakes :p
      zachary louisiana
      you can get some good money for factory brakes....boss sold his for 200 spindles and all.....and you could get alomost all the ls1 stuff for 200 here is what i paid
      calipers and brakets 100 napa
      stainless steel lines... precision brakes 85
      cnc braket rich..? 50
      spindles i had and new hubs 30
      studs bolts pads and rotors 100
