    Results 1 to 9 of 9
    Thread: AWW Crap
      AWW Crap
      went to the track last night and blew my motor on the 1st run. 1/2 way through the run it started making a horrible valve train noise and oil pressure dropped shortly after that i shut her down and put it on a trailler. pulled it today and started tearing it down. found out that the roller lifters that are on the #7 cylinder came apart and ground the lobes of the cam on that cylinder, sending metal flakes through the motor. luckaly the cylinder bores look good, no scars or anything like that. hopefully it is salvageable. just gives me an excuse to put in a larger cam and probally a solid roller. it wasnt even a good run, 14.2@94
      since i need to rebuild it i might just put in a 400 thats under my bench. I think that would be better suited for drag racing, and going fast. Plus that way if im out somewhere and something happens to me(drink too much) and i cant drive home anyone can, so im thinking about selling my TKO 600 thats on my 396, 1300 miles with flywheel, clutch and pressure plates, lakewood scattersheild. shifter, etc. so if anyone is interested let me know.
      Macon, Ga.
      Great, two days after I buy a T56....
      Let me know the specs on the camshaft you want. I have a brand new one, never installed, solid roller. I ended up using a hyd. instead.
      Bill
      Trailers are for BOATS!
      Dunwoody, GA
      sucks man. at least you get to build it back stronger than ever this time. good luck with it all.
      Trey
      ~ Jon Hammond
      Bill, right now i have a 236/242 @.050 610/610 lift. its in a 396. i would like to stay around there, maybee a little larger.
      im glad i get to rebuild it a little stronger now but this isnt a good time. im in the process of buyin a house so all my money is tied up in that. o well i will figure out a way.
      Metamora, Illinois
      How much for the complete TKO setup?
      rocketrod, would you want the used clutch and pressure plate? or just tranny flywheel and scattersheild?
      NH
      What ratio is 5th and where is it located? thx Bryan
      Beegs AKA Bryan
      5th is the .64 and im in auburn NH just outside manchester.
      NH
      PM sent
      Beegs AKA Bryan
