      Crestview FL
      Somthings wrong ... need help
      I was getting the camaro ready for the drags tonight and when I started it up I heard what sounded like a metallic ratteling commin from somewhere around the valve covers/ bottom end... I am having a hard time isolating the sound.. it is rpm sensitive if I wrap it picks up speed... it sounds kind of like a vibration... my gut feeling is that it is not internal but maby a loose conection somewhere.. It is not a deep thump like a rod knock but a higher pitched almost like an air cleaner that is not secured right... I pulled the valve cover and watched the pass side no problems and i pulled the air cleaner... no problems... ALso it seems that if I put it in gear the sound goes away??? ANy Ideas?? should I be worried ???
      montgomery, IL
      check out the exhaust it could be an exhaust leak they sound like a metallic tick knock
      "Too bad Dare to Be Different these days could mean Dare to Be Fast. What ever happened to the Cars that Scared people?" John Pearley Huffman
      California
      is it an automatic? it could have a cracked or broken flexplate.
      Crestview FL
      it is an auto.. and it does sound like the sound is comming from the back of the motor.. in that area.. i will have to put it up on the wrack and check it out...
