Results 1 to 1 of 1
Thread: Mounting Flaming River???
04-13-2006 #1
How does Flaming River tilt steering column mount to my old dash? The original had the firewall cover which I will put on the new column, but the two main mouting bolts that go right by your knees or exempt from the new column. The original column had a plate bolted to it and this plate bolted to the two studs hanging dwon from the dash. So does Flaming River expect you to buy their column dash mount with ignition for $140!!!
Justin
73 Nova, 502 ci, TKO600, Mosier Eng 12 bolt, 6 point roll cage, Wilwood rear discs, factory front discs, 250 HP nitrous, subframe connectors, Slide-a-link trac bars, 17" Boyd Coddington Smoothie II's, and Hotchkis TVS kit.
