    Results 1 to 20 of 24
      What compressor with LS1 and Vintage Air
      What compressor should I run in a 69 Camaro with and lS1 and vintage air?
      Nov 2000
      O-town
      Sanden 508, now you have to pick which goofy bracket you want to run
      Macon, Ga.
      Street and Performance probably has a bracket that you can use.
      Bill
      Trailers are for BOATS!
      Sep 2003
      Tampa, Fl
      They do but it moves high on the passenger side. Kit around $600.00 last time I checked a couple years ago.
      Brian
      '68 Chevy Stepside-Fatman, HTH, 8.8, Baer, Hydratech, LS1/T56. I know it's a truck but you gotta start somewhere and I need the challenge.
      Nov 2000
      O-town
      There's a newer one out now, not so much monies,
      Central Florida
      Quote Originally Posted by Steve68
      Is this an S&P piece?
      Nov 2000
      O-town
      Yes it is, smaller bolts to the head, and polished, bling bling, it should be on there page,
      Can you use the factory compressor that is used on the ls1?
      www.paintbyjohn.com
      Nov 2000
      O-town
      No, the VA system and the GM system are variable pressure systems, It would work for alittle bit, and then the system would grenade itself, thats what I was told by a reputable VA installer,
      Steilow built a bracket system for a Sanden, but I don't know what pully he used,
      charleston, SC
      Vinatge air makes a bracket that puts it back in the stock location. It came with the kit ordered from Detroit Speed.
      Robert's 1969 Camaro - 2002 LS1/T56, 10pt cage, Global West Stage III front suspension, HTH truck arm rear suspension, Sprint Cup 9" full-floating rear end, Fikse Mach V 17" up front 18" in the back and still working on it...
      Nov 2000
      O-town
      They must have finally come out with it, awhile ago the sent me a pic of a so called proto type, I wasn't really that impressed with it, but I'll check it out now,
      Katy,TX
      S&P mount
      S&P sells one that mounts a Sanden in the original Fbody location,(lower right) but moves it forward to miss their motor mount plates. It deletes the original A/C belt and runs off the front belt.
      Charlotte, NC
      this is one I used from S&P.
      It will work on a stock subframe but you will need to notch it a bit.
      Quote Originally Posted by Payton King
      What balancer and crank pulley are you running?
      Charlotte, NC
      I was using
      Stock LS1 F body stuff
      Nov 2000
      O-town
      PK, come on man give us a closer pic PLEASE!
      oh buy the way very nice!
      Charlotte, NC
      closer pic of the compressor and braket?
      If you go to www.hotrodlane.cc they have an online cataloge. I think it is on page 60 but not sure. I am using the system that retains the stock GM bracket (fbody) for the power steering and pump.
      Tell me what you would like to see and I will get you a shot
      Pittsboro, NC
      Looking real good Payton!
      Apr 2003
      chbg, pa
      It will not work on a stock subframe!!!!!!
      Nov 2000
      O-town
      So, you still need to make a cut out, anybody see the on MarkS used on X he made his own, but I think you need to add another pully to the hub.
