      Tko Syncromesh Fluid All Three Quarts?
      Should this tranny take all three quarts or is it acceptable to have only 2 3/4 go in? I say this because I had the fluid start to come out of the fill plug after about 2 3/4's. The car is at ride height and not tipped back or forward, THanks in advance!!
      Mark
      TOOFUN
      Motor City
      Mark the official capacity is 5.28 pints, which is 2.64 quarts. You're good to go!
      Mike
      Thanks again Mike... This is the third time you bailed me out.
      Mark
      TOOFUN
      Welland, Canada
      FWIW I just filled mine on the garage floor until it just came to the bottom of the fill hole. It took pretty well all 3 quarts, maybe a 1/4 inch left in the last quart. I filled mine before installation just to see if there was any leaks, and so far all is good. Thankfully the output shaft plug is holding up so I can install it without a mess.
      Dean
      69 Camaro 355-3.73 Moser Truetrac-TKO600-Hotchkis-DSE-QA1's-Baer's-17"Budnik's
      ST U/LCA's-GW Del-a-lum's-Lee p/s
