Results 1 to 1 of 1
c5 front suspension measurements needed
can anyone give me the distance between the front upper and lower control arms horizontally measured at the pivots and vertically, the uca and lca width and length, and the length from the outside of a 9.5" wide wheel to the lca inner pivot, and the ldistance from the hub centerline to the tie rod hole in the steering arm. thank you if any info is available.
