    Results 1 to 13 of 13
      IN/MI border
      Epoxy on Garage floors?
      I bought a few kits to do my garage floor, has anybody used the Rust Oleum Epoxy floor kit? Here's my worry, 8-9 years ago (when my garage floor was new) I put one coat of Thompson's water sealer on it. When water is on the floor it does soak in within a couple minutes. The Epoxy kit says if a floor has been sealed, that it may not adhear properly. But there is different types and variables of garage floor sealers too.
      So basically, has anybody used this and had a issue due to grease, oil or sealer under the epoxy before? I already have scrubbed down the floor and plan to coat it Teusday.
      Nov 2000
      O-town
      you need to acid etch the floor, Check with the do it yourself places. The Depot, Lowes etc. they should be able to help you, My brother put dwn the gray epoxy the you sprinkle the little dots on top of that stuff is awsome looks great, the old neighbor painted his floor with some stain would peal up with hot tires, since you did the water seal, which has probably worn away now, I would etch it,
      I am going to be doing the rustoleum this weekend! The kit comes with a citric etching compound which may work. I would suggest acid etching it first then use the citric in the kit. Problem is in non traffic areas the sealer will still be there.
      Let me know how it goes so i have some pointers! (other than having a good supply of beer on hand!)
      IN/MI border
      Yeah it had the citric blah blah something or other in it. So does that do some etching? There was never any high traffic on this floor. This will really throw off my schedule now since it'll be getting back into the high 50's in a couple days, and would need to wait for the floor to dry.... crap! I may just do it tommorow anyway. Garage door is open right now letting the floor dry out.
      South Dakota
      Use muriatic acid on it first. You can get it at any decent hardware store. Mix it with water, pour and broom it on a 100 square foot area at a time, rinse it off. Does take a little while to dry again but sure beats the paint coming loose. Did my floor last summer. Holding up great.
      Steve Lenning
      69 Camaro LS7/T56
      69 Camaro SS396/350hp
      70 Camaro-just getting started
      64 Chevelle - waiting it's turn
      2010 Camaro 2SS/RS 6spd
      South Dakota
      BTW I did a beige floor with black and white fleck. My wife walked around in metal spike golf shoes to spread the fleck. Heres a pic showing my floor (and my 12 bolt) .
      Steve Lenning
      69 Camaro LS7/T56
      rustoleum product explicitly says do not use muriatic acid. I too have been waiting to do this to my garage but here in NY its either to cold or raining all the time. Chris
      South Dakota
      I did use a different epoxy on my floor so I didn't know not to use muriatic acid with Rustoleum, sorry bout that.
      Steve Lenning
      69 Camaro LS7/T56
      IN/MI border
      Thanks guys. I noticed the same thing about it saying not to use muratic acid. I thought maybe it was just to do with breathing it in?? I have a bottle of it here at the house. Gotta watch the fumes on that stuff though, practically starts rust on metal almost on contact!
      Scott, yeah I thought ahead knowing I'd be tracking snow in and out of there a lot LOL! They make a grit you mix in with it to enhance traction. I ended up putting up a divider wall in the garage and am using VCT tile on the shop side and will use the epoxy on the car side (but will be awhile before I put it on now). Drove by the cottage the other day... it's looking good!!
      IN/MI border
      well, decided to use VCT on the shop side of the garage. Just finished it up Friday night. Going to epoxy the car side a couple months down the road. It turned out pretty slick. Threw in a wall to devide the shop and car side with a 12' 4 panel sliding door to move smaller items in and out.
      Metamora, Illinois
      That looks great! Where did you get the VCT? I am getting ready to move and want to do something similar.
      IN/MI border
      Thanks! You can get it at any of the big building goods stores (Lowes, Home Depot, Menards). There's a couple brands out there, I used Armstrong. If you go into one of those stores just say you are looking for some Commercial grade CVT tile. It's basically the same stuff you see in schools and those type of buildings. And they are cheap at around 57 cents per sq/ft.
      The colors in the pic are altered a bit but I have tan walls so I used black and tan tiles.
