    View Poll Results: Don't Spindles or Springs
    Voters
    27. You may not vote on this poll
    • Install Drop Spindles
      3 11.11%
    • Install Drop Springs
      20 74.07%
    • I have NO IDEA....
      4 14.81%
      Edmonton, Alberta, CANADA
      Drop Spindles or Drop Springs
      I have read posts on both sides of the fence
      OK... Post your decision or opinion.
      Mar 2003
      Kirkland, WA
      I've heard that most of the drop spindle kits limit your brake choices. Plus you could run into tie rod clearance issues depending on the rim you are going to run.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      New York City
      I'll 2nd that. Dropped spindles limit the front wheel width and backspace too much. See the photo on David's site. Jack
      Oct 2003
      Arvada, Co
      That is all true for first gens, but he has a 2nd gen. Does this still hold true?
      Brian
      Apr 2003
      Nyköping, Sweden
      Country Flag: Sweden
      I think it is the same for all applications. The worst part with Drop Spindles is that the geometry gets all screwed up.
      Jan
      Jan Suhr
      Nyköping, Sweden
      1969 Pro touring Camaro Z/28 LS1/T56
      Scandinavian Pro Touring Forum protouring.se
      Mar 2003
      Kirkland, WA
      I thought that the sole benefit of dropped spindles was that they maintained stock geometry of the suspension. Not that many of us are looking for that.
      James
      -1996 Z28
      -2005 Silverado
      Webpage
      Central CA USA
      It might be OK on a second gen Camaro because the Tie-Rod end is higher, not near the rim, but it will drop two inches with a drop spindle so it's going to be closer to the rim.
      Dropping with springs sets the suspension on a part of the curve with more neg camber gain. The lower arm won't be ideal but it'll work ok.
