    Thread: Gas Tank for FI
      Oct 2005
      Gas Tank for FI
      Other options instead of a rock valley tank for an EFI conversion in a 69 camaro i was thinking of maybe a buick grand national tank might fit.
      Here is a link of dimensions:
      http://www.1aauto.com/1A/GasTanks/Bu...GT00302/273643
      and the camaro:
      http://www.1aauto.com/1A/GasTanks/Ch...aro/GM32B/8675
      any ideas?
      Seems like they might be close enough to modify the filler neck and possibly the straps...
      st peters ,missouri
      96 caprice has been used.
      Oct 2005
      Do you know much modification was needed in order to make it fit? any more info/ pictures appreciated
      st peters ,missouri
      The guy had to make the straps longer cut out a spot in the floor and put a access panel/cover. He didn't have a chevy rearend in it so he had to take a heat gun to the tank and reform it alittle. Was not to bad since it was plastic.I saw it on ls1 tech in the conversions and somewhere else.If i find his website,I will post.
