      Maximum fuel economy when designing engine?
      Hello all--newbie here.
      When you are designing an engine, what do you do in order to get good power but also good fuel economy? I purchased Dynomation dyno simulation software to help me design but am at a crossroads.
      I hear that if you want good fuel economy, stick with low rpm torque, which basically makes for a tow motor I think? Not a lot of accleration but good throttle response (they say)--whatever that means. I was also told that building a 'red light rocket' will make for very bad MPG. This is for a daily driven street vehicle--I don't race.
      Goals are something like 350+ hp, plenty of torque (400+?), 250k miles, and 25 mpg. I'm willing to put on Tri-Y's, a 4L65e so I get overdrive, etc. This is going into a first generation Monte Carlo.
      I know this can be done as I've personally ridden in a 350k+ mile 72 Impala convertible that gets 22 mpg with no overdrive, 4-into-1 headers, and highway torque that beats anything I've been in, all out of a large displacement naturally-aspirated small block. Part of the reason for my design is to surprise this person (my mentor) with an engine of my own without letting him know.
      My current plan:
      small block Chevrolet
      4L65e
      Tri-Y
      Jacobs ignition
      Eaton limited slip
      3.23 (or so) in the rear
      BFG radial T/A tires,
      and the list goes on and on, but wanted to give an idea.
      Would an engine built to these specifications be more of a highway cruiser or a red light rocket? Given three wishes, one would be torque especially in the 30-90 mpg range but I'm open to discussion.
      Any input would be appreciated.
      East Coast Florida
      Hey Hammerhead, welcome to the site.
      This book is a good place to start:
      PERFORMANCE WITH ECONOMY By David Vizard. Detailed guide points the way to top performance with good gas mileage. Includes choosing low-restriction catalytic converters and mufflers, turbocharging for maximum performance, using octane boosters, etc. & lots more. 8 1/2" X 11", 128 pages, 335 photos. Sftbd. Item # SA09...$18.95
      Good Luck with your project.
      Project "Freebird"
      dayton ohio
      teflon/thermal coatings, and roller bearings everywhere. keep the cranking compression in the 180-210 psi range.
      POLITICIANS & DIAPERS BOTH NEED TO BE CHANGED, AND FOR THE SAME REASON!
      thanks
      Thanks for the input--I'll have to try and locate that book.
      How does the torque curve, manifold vacuum, that sort of thing, determine fuel economy?
      Belle Plaine, MN
      The less the engine has to work, the less fuel it will use. If it's got a nice long stroke that makes gobs of torque, it will be able to lug the car along on the freeway in O/D without much effort. Let's say this requires 150 ft-lbs., and a well-built 406 can do this at 1,400 rpm.
      A 327 with a shorter stroke may need to go to 1,800 rpm to acheive the same thing...and may use more fuel in the process even though it's a smaller-displacement engine.
      Designing the powerplant to run comfortably in overdrive means careful consideration of camshaft, rear axle ratio, and rear tire height to coordinate in a refined package. The transmission's O/D ratio is part of this formula.
      mph = (rpm x tire diameter) / (gear ratio x 336)
      rpm = (mph x gear ratio x 336) / tire daimeter
      gear ratio = (rpm x tire diameter) / (mph x 336)
      tire diameter = (mph x gear ratio x 336) / rpm
      I hope this helps.
      ~SP~
      Scott Parkhurst
