Thread: max-g suspension help?
04-03-2006 #1
Starting The Transformation
- Sep 2005
- new zealand
- 113
hi there all ,heres the details max chassis ordered with 5in ride height the rear is sitting at that now ,the front is at 5 3/4in pointing the car uphill the front shocks are at there lowest setting the lower A -arm is not parrallel as it should be or that was what i was told the only fix i see is relocate the the top mount/install a shorter shock also the front shock has 30mm travel before hitting bump stop iv included a front on shot if theres something iv missed please say and ill try to explain hope theres asusspension guru with some wise words cheeers darrin
04-04-2006 #2
- Oct 2005
- SoCal
- 489
. . . , . , . , , . . . . , . . . , . . , . , . . You forgot those. What is the extended eye to eye length of the shock under no load? How much shock travel is available? If you remove the shock, set the car where you want it at static ride height, what is the eye to eye length on the mounts? At that height, how much wheel travel do you have till it rubs or hits the bump stop? Is a shorter shock/spring readily available? Maybe it's just the illusion of the picture but it looks very short eye to eye as it sits.
04-04-2006 #3
- Feb 2005
- 320
Hiwayman Is it possible you have the rear shocks on the front and the front shocks on the rear. I remember when I spoke to Don over at art morrison the two were different lengths at least for the solid bars I was going to make for temporary use. I hope that is all thats wrong man. Anyways E-mail som more progress pics. Chris
04-04-2006 #4
- Sep 2005
- new zealand
- 113
hey there prostreet yip the car has been set up as you mentioned static ride height the eye to eye measurement 11in, the shock measures 12in set at its lowest setting shocks are avalible shorter body but to get them down here pricey, chris have you sorted your shock combo ride height yet may help me figure this out?please keep the replys comming maybe thers something iv missed thanks darrin
