      San Francisco, CA
      suspension? stiffened
      A little while ago I was seeking your guys' advice on how to stiffen up the suspension on my 71 el camino, which was having horrible front-to-back boat-like oscillation. Cutting to the chase, you guys told me I needed some new shocks. Since I thought the front was the problem, I thew on some edelbrock performer IASs on the front only, and threw in a suspension techniques 1 1/4" sway bar as well.
      This has improved the ride and handling tremendously. I can actually mash on the freeway topped out and not fear every minor change now. Performance on the bumpy potholed streets I frequent is also much better. A little on the stiff side, but way better than the boat it once was.
      There is a question in this: the old (but still brand new) kyb gas-ajusts are still on the rear. Because I have cargo coils which makes the rear sit about 1 1/2" higher than stock, I had to go with a part number which is for a 78' (or that gen) el camino, because my shop told me that if they installed the p/n for my 71', they would have to stretch them out to install them and they would wear out prematurely. Is this true?
      Because I am loving the edelbrocks on the front so much, I might want a pair on the rear as well, but I don't want to bother with fruitless part number searching or install something that fits but doesn't actually perform as it should, thanks for reading this essay.
      Dec 2003
      lost
      Looking at your picture from your first post it doesn't look like it your Elco is raised up very much. Maybe 1.5" over where it sat when you got it but not over stock. I would suspect that stock shocks for your application would fit fine. Make sure your shop knows it is perfectly normal for the springs to "pop" out when the shocks are removed and for it to be necessary that they use a screw jack of some sorts to raise the axle into position to attach the shocks.
