    Results 1 to 11 of 11
      Dayton,OH
      DSE coilover install questions...long
      First post! Long time lurker...
      Finally got around this winter to welding/assembling my DSE coilover setup...and I just got the subframe back from the powdercoater.
      Can someone roughly outline the assembly procedure (I moved this summer and now can't find the directions) I have attached the a-arms.
      I think I need to:
      1. Compress the spring externally (1" maybe?)
      2. Insert shock
      3. Tighten up the coilover adjusters. I have the BBC springs (650#) with a BBC/Alum intake and heads/alum radiator/battery in trunk/Hotchkis rear springs/17" wheels. I'd appreciate rough "dial-in" from anyone...sweet as this setup is, it looks like a real PITA to adjust more than once...
      4. Mount it up...upside down.
      I need a different external spring compressor, the knuckles of mine had too much steel inside the spring and interfered with the shock, so I couldn't use it. Brand/Store of one that works?
      Any other tips/tricks?
      Thanks for everything,
      Scott
      1967 F-Body
      Jul 2003
      allen, texas
      The spring should assemble as part of the shock to make a unit and require no crompressing. Have you tried e-mailing DSE to get the directions form them?
      Dayton,OH
      It was nighttime/weekend, so no I didn't call oremail dse. will do it today of course...thanks
      yes, I assembled the spring/shock, but without compressing, I don't see how I'm gonna attach to the a-arms...also, I'm pretty sure you have to compress the spring some minimum distance as a preload.
      I searched the site but didn't find any pics...i recall a long time ago a post by tito? that had a great step by step photo montage, but I couldn't find it.
      Scott
      Jul 2003
      allen, texas
      set it up so there is little/no load on the adjuster so the spring has no slack in it, then once you get it on the ground adjust it to your liking
      from there.
      Oct 2003
      Arvada, Co
      Do you have the spanner wrench for the adjustment nuts on the shock body? That will be of great help in changing the ride height on the shock.
      Brian
      Dayton,OH
      homerneedspeed, i see what you are saying, but once the shock assy is installed, how do you adjust the rings, they are inside the frame...what am i missing?
      baz67, yes I have a spanner wrench...moroso i think...
      thanks for the help guys...appreciate it.
      Scott
      Scott
      1967 F-Body/ZZ454
      May 2002
      Southeastern WI
      Quote Originally Posted by 67Therapy
      Scott
      Check out this earlier post. I asked the same question.
      https://www.pro-touring.com/forum/sh...ad.php?t=13869
      Jeff
      Dayton,OH
      VanB,
      I saw that post...I hoped someone who had the DSE kit with a BBC could ballpark my first attempt.
      Right now mine is installed per Homerneedspeed's suggestions, but it will be awhile before I get the engine/wheels/and sheetmetal back on to see what the ride height will turn out to be.
      Thanks all for the help.
      Scott
      Scott
      1967 F-Body/ZZ454
      Jul 2003
      Anaheim Hills, CA
      Im sure DSE would fax you a copy of the install instructions..
      1968 Track Rat Camaro:
      Feb 2006
      South West... Viva la New Mexico!
      post up some images if you can.... I would like to see how it is coming along
      Dayton,OH
      I finally got around to taking a couple of progress pics. Thanks for all the help along the way.
      Scott
      Scott
      1967 F-Body/ZZ454
