Thread: upper radiator hose collapses
04-02-2006 #1
I am having a high temp problem. I have a 67 Camaro with a 327 that is somewhere around 375HP, I have a Be Cool direct fit aluminum radiator with a 16lb cap. I have a sealed recovery tank (only has the input fitting, and on the bottom has a petcock to drain it, no return fitting), I have the MKIII fan and DC controller wired to the battery junction block (battery is relocated to trunk), I have a 180* thermostat. When I start the engine the upper radiator gets sucked together. My temp runs at around 180* at hwy speeds, but in stop and go city driving it rapidly goes up to 210-215* I have both jumpers installed (pins 7-9 and 8-10) which should decrease operating temp by as much as 36*. I believe the major problem is the upper hose getting collapsed by vacuum from somewhere, what could be causing this and how do I fix it? Thanks for the help.
-George
