    Results 1 to 16 of 16
      Turn key engine supply
      Im looking a buying a new ls1 from a company called turn key engine supply.Anyone know anything about them.Heres what Im getting as a package kit.new ls1/stand alone wiring harness/new ecm/75 mm throttle body/all sensors/block offs/alternator/water pump/serpentine belt system/jet coated shorty headers/fuel pump kit/an fitted fuel rails/fuel pump/pressure reg./flywheel/k&n air filter oil and filter.7600.00 seems like a great deal to me 410 HP. 12,000 Mile warranty. any better deals out there? thanks Tim
      Feb 2006
      Only thing is see better is their ls-2
      seems like a great deal.. for $2400 more you can get the ls-2 which is (at the fly wheel) 510hp and 480 ft/lbs.. so it's $24 a hp... i'm not sure with bolt on you could get that HP and torque out of an LS-1 for less then $2400.. the afr or CNC heads alone would set you back close to that..but i'm not sure..maybe you could
      Mountain View, CA
      The upgrade is a great deal. The AFR heads are $1500 alone.
      True T.
      My blog
      pittsboro, nc
      a while back i added up parts on building new ls1 & turnkey was $1400 cheaper than what it would cost to build. on the ls2, they were a couple of hundred $'s more, but the hp on their ls2 was really bumped up.
      Thanks for the input,Sounds like I will be making a call.
      pittsboro, nc
      give us some feedback if you get one
      Feb 2006
      What is the word on their LS-2 510/480 motor? What did they do? I picked up a handout at a show and under features it lists a performance cam and manual 90mm TB. I assume those numbers are w/out an exhaust. I wish they put a graph in the handout or on the website so I could see what the numbers are from 2,500 to 6,800. Would an aggressive cam put up 110/80 over stock?Or is the big increase over stock due to no emissions/ or restrictive exhaust? I wonder if their is some head/ valve work that is unlisted?
      pittsboro, nc
      Quote Originally Posted by murtah
      they add headers, different injectors, fast throttle body & computer retune
      Feb 2006
      I have the dyno sheets from turnkey
      I have the dyno sheets from turnkey for the ls-1 410hp and the ls-1 450 anyone needs them you can e- mail me at [email protected]
      Encinitas, CA
      I highly recommend them. I used one of their motors for my project: http://www.classicchevy5speed.com/Si...let_Camaro.htm.
      They have a great facility and they ar egood people.
      Jeff Mortenson
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by jeffmort
      BTW.. was at the shop today and saw your project.. and your Turn-Key engine.. VERY nice..
      I took the liberty of snapping a cool "under construction" pic.. wonder what I could use that for??? lol
      Cars making good progress!
      1968 Track Rat Camaro:
      good to see good reviews about them,I talked to cody?I think that was his name.Answered all my questions.I will be giving them a call next week.What motor did you end up getting from them? I also see you are owner? of classic 5 speed.I wold like toget some more info on a 5 speed for my car.could you give me a call 317 258-8063.Thanks Tim
      Chicagoland
      We offer similar packages and prices and are a supporter of this site.
      thanks
      www.schwartzperformance.com/products.htm
      Jeff Schwartz 815-770-0751
      SchwartzPerformance
      Where classic style meets modern performance.
      455 Commanche Circle
      Harvard IL 60033
      SchwartzPerformance.com | Facebook | Twitter
      pittsboro, nc
      Quote Originally Posted by jeff s
      thanks
      looked on your site & didn't see any engines. could you quote a turnkey ls1 & give details of what's included.
      Ok jeff,give me a price and whats included.Thanks Tim
      Chicagoland
      Quote Originally Posted by shanekennedy
      Just click on that link above here and scroll down to the second picture. There's a supercharged LS2.
      As stated earlier our prices are competetive with all the other's.
      If you're ready to order, call me at 815-455-2230 or email [email protected] for an exact quote. I don't have time to check these forums much.
      thanks
      SchwartzPerformance
      Harvard IL 60033
