    Results 1 to 13 of 13
      Oct 2005
      Florida
      383 stroker questions
      Im gonna buy a 383 stroker from recon for $2000. Its not that bad but considering im only 17 and have a tight budget its all i can afford. here are the specs that i got on it:
      Dart heads w/ 2.02 1.60 valves .560'' lift springs
      cam has a lift of 4.88 int. .510 exh. w/ 114 lobe sep.
      it is rated at 400hp and 440 lb
      What cheap upgrades can i do to it to beat my dads SRT-10 viper?
      1969 Chevy Camaro 350-8th cylinder gone =[-
      2005 Dodge Viper SRT-10 505/ 510hp
      mo
      better flowing heads,and bigger cam,good single plane intake manifold
      Farmington Hills, MI
      Agreed with above.
      But if you are going for cheap HP, Nitrous. A carb plate system should put you up to 550hp if tuned right, and it wont hurt the buget too bad.
      JEff
      JEFF SHORTT
      -IDEAL STEEL
      Dunwoody, GA
      better traction
      Trey
      ~ Jon Hammond
      mo
      what kind of a bottem end does that have for 2g.and like above mentioned it better hook up.
      Jul 2002
      Muskegon, MI
      When you say you want to beat your dads viper are you talking road courses or drag strip? The engine is only the beginning but a 383 is a great start. $2000 is a good deal.
      Sep 2002
      San Jose, CA
      $2000 for a complete 383 - too good to be true, stay away from it.
      Time for my speech on engine prices...
      There is very little profit margin on engine parts, at best 35%.
      All professional engine builders pay about the same for their engine parts.
      Yes there is some money that can be saved in machine work, though lower employee wages ect... BUT we are talking about less than $1500 savings AT BEST.
      So - using this information we can infer:
      If you find an engine for signifigantly less money than everywhere else than something major is either missing, substituted, or done half-assed.
      FYI A properly done 383 stroker should cost $5000-$8000
      Just call me Brett
      East Coast Florida
      Quote Originally Posted by Fbody69
      Nitrous...
      Project "Freebird"
      Iowa
      Lowend is right, I had a 383 built just this past summer and it also has Dart heads, Eagle rotating assembly, big solid cam, 6" rods, wisco pistons... etc... With all the machine work, balancing, head work and assembly of just the long block, I've got well over 6K in it. And I didn't go with all the High end goodies, just a step below that. So I'd almost be safe to say that "it's almost too good to be true." Just my .02 worth. Good luck Trond.
      Jul 2002
      Muskegon, MI
      Quote Originally Posted by Lowend
      I dont agree with this $5,000-$8,000 statement. I had mine built for $3,000 about 2-3 years ago and it has somewhere around 400hp.
      Sep 2002
      San Jose, CA
      what is your combo?
      Just call me Brett
      Jul 2002
      Muskegon, MI
      I guess stock cast iron heads make it a little cheaper too. But considering how well this car runs I cant even imagine what aluminum heads would do to it!
      -10.5---11 compression
      -keith black pistons
      -clevite mains and rod bearings
      -chrome molly rings
      -hydrolic cam
      --12250-3 comp cam extreme energy cam 240 --- 246 duration
      510 lift 110 lobe separation
      .50 duration
      -eagle rods
      -cast crank
      -edelbrock performer air gap intake[edl-7501]
      -1970 heads194/160 valves machined for larger springs
      -screw in rocker studs
      -push rod guides
      -rev limit 7,000rpm
      Sep 2002
      San Jose, CA
      Its not bad... kinda mismatched.
      I would be suprised if it makes more than 400HP
      Just call me Brett
