Results 1 to 20 of 30
Thread: New Pro-Touring (sort of) GTO
- Feb 2006
- 478
Well after much deliberation and fussing over styles and backspacing and all, I finally got the new tires and wheels on the Goat. They are Intro Vistas, 17x8 with 245/45s and 18x9.5 with 295/45s. The front has 5" BS and the back has 5.5" In the back I have good clearance on the inside. Probably could have went another 1/4" on the backspacing. One the outside, I am going to have to remove that hump that is above the wheelwell lip. No biggy. The front seems to be perfect, I haven't gotten to drive it yet, and the whole car neds to come down a little more. The front is going to come down about 2-3" and the back about 1/2-1"
I am pretty stoked about getting it out on the interstate and running it out. I have a 550+ HP 461 and a TKO 600. Before the tires, I ran it up to 120 a few times, and it wasn't even breathing hard. It should run 150 pretty easy I would think. Not the most aerodynamic body style GM ever made though.
03-23-2006 #2Looks great! I'll always have a soft spot for Goats... I hope you have the brakes to slow that beast? Not a liteweight at all... Keep us posted.
Camaro Convertible Build Pics - http://s447.photobucket.com/albums/qq198/rob07002/
www.musclerides.com
Rob Stevens
03-23-2006 #3
- Feb 2006
- 478
It has a tall spindle conversion on the front. 12" power discs. It will stop very good. It still has the drums on the back, but the brakes are at least as good as my 02 Trailblazer or my 02 shortbed 2wd pickup. I might put rear discs on sometime for looks but the brakes are great already.
You would think the car is heavy, but it will surprise you. I has aluminum heads and no air or spare tires and jacks and all that, I weighed it before the aluminum heads and it weighed 3360, with 1940 on the front end. Since then I moved the battery to the trunk and put on aluminum heads. So I figure the front weight went down 100-110 lbs and back weight went up 45. That is about a 55-45 ratio front to rear and a 3300 weight. Not bad for an all steel A-body.
03-23-2006 #4
New to Pro-Touring
- Jan 2006
- 11
Is that a '66?
Its absolutly gorgeous
03-23-2006 #5
- Feb 2006
- 478
Thanks for the comments! It is a 67.
03-23-2006 #6
