    Results 1 to 1 of 1
      dayton ohio
      turob id help needed
      i got a t3/t4 hybrid off of an eclpise gs today and it needs a new center section. it is a turbonetics turbo. i am not sure of the wheel trims or the compressor a/r. it will not be used for a lsx engine due to its small size. i need help identifying the compressor a/r, trims, and center section.
      the numbers that i have found on it are:
      side of turbine inlet -- 20357
      inside on turbine inlet -- .63
      side on compressor -- j1001
      compressor end of bearing housing -- 20542
      again, i would like to know the compressor a/r, what trims wheels, and who is the best place to get a reman/balanced center section to match both of these housings. i will probably end up putting this on my d/d beretta.
      thanks
      kevin
      POLITICIANS & DIAPERS BOTH NEED TO BE CHANGED, AND FOR THE SAME REASON!
