    Results 1 to 1 of 1
      Brake biasing setup
      My current setup is C5 rotors, calipers and master cylinder. After doing some math, I came up with the fronts being 130% of stock and the rears being 87% of stock. How can I tell if I have enough rear brake?
      I was actually thinking of adding C5 fornt rotors and calipers to the rear then using an adjustable proportioning valve to balance everything out.
      How do you guys know how much to adjust the rears? What signs are you looking at to see if it is right.
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
