Results 1 to 11 of 11
- Jan 2005
- Johnstown
- 99
Having problems w/C5,LT1 conversion on my Malibu
I have been working on this darn thing since January. I have a 79 Malibu w/C5 front disc and LT1 rear disc. I have a brand new master cylinder from an 88 Monte Carlo SS. I installed a dual diaphram brake booster for better vacuum. The problem I am having is that the brakes are fine in traffic when you are using them alot and even in reverse. But when you drive the car a few blocks without using the brakes the pedal gets soft and goes down before the brakes kick in. I replaced the booster and master cylinder and that really helped. I have bleed the system so much that I have ruined my chrome lug nuts. If there is air in the system I don't know were it is. I am beat my head on the wall! I don't know what to do. I called Baer and the first time I talked to them they told me there was air in the system. So I bled the system and nothing. Today when I called they told me to cheak the vacuum. But I don't think that's the problem. I have never had a problem with vacuum. The only thing I have done to the motor was I went from a 750 cfm carb to an 800 cfm. Do you guys have any suggestions? Any help would be great. At this point I will do anything. Thanks Andy
03-20-2006 #2
- Oct 2004
- 12
Isn't the master cylinder from the monte carlo for a front disc rear drum? The master cylinder might not have enough stroke for the brakes to work correctly.Check into a disc/disc master cylinder. I had a similar problem using a master cylinder from a 3/4 ton chevy but again that was a disc/drum master cylinder so it didnt help either. In the late 90's I was trying to set up 4 wheel disc with lincoln rear calipers and there wasn't alot of info out there, so needless to say I ended up scraping the project. I am going to give it another go with a set up similar to yours.Keep us informed when you get it sorted out.
03-20-2006 #3
