      St. Louis, MO
      C5 2nd Generation Brackets
      I know a few guys here have done the C5 swap on a second generation camaro/firebird. Does anyone have a template or the actual brackets for sale? Secondly, I have seen the pictures for the front brakes, maybe I am missing the rear ones, but has anyone done the swap for the rear brakes as well?
      John
      dennis68 Guest
      I can get you a set if you are interested-they will run about 75.00 for 7075 Al brackets. It may take a couple weeks, let me know.
      Pittsburgh, PA
      4th Gen
      john,
      Most guys are using the LS1 4th gen rear brakes with c5 fronts. The friction surface size is essentially the same thickness (12") & diameter (1"). The backing plates bolt onto the axle flange of 10 & 12 bolts. The baskets are different than the c5 but the calipers are identical. If you want to keep the stock shock locations you have to use backing plates from the same side of 2 donor cars.
      Lots of info on this swap in here.
      Shane
      St. Louis, MO
      Brake Swap
      Thanks for the Responses.
      Denny, I have a 78TA, your post mentioned a 70-75 Bracket... Will this still work. The time is not a big deal for me.
      John
      dennis68 Guest
      Yeah, same spindle. Let me know.
      St. Louis, MO
      C5 Brackets
      Yep, I would like some. Private Message me, and we can work out payment arrangements. Thanks.
      John
      Central CA USA
      http://home.earthlink.net/~kiszka/C5_brake_upgrade.htm BIG BRAKE SWAP PAGE This spindle should be the saame as a second gen.
