    Page 2 of 2 FirstFirst 1 2
    Results 21 to 23 of 23
    Thread: Welding table
    1. #21
      Elgin, IL
      The best table I have ever seen was at Ingersol Milling Machine in Rockford, IL. It was maybe 4'x5' with about a 1 1/2" top. The top had two sets of parallel grooves 3/4" deep x 3/8" wide. The fabricator would drop 3/8" x 1 1/2" flat bars in the grooves to make right angles.
      Then clamp the work to the bar stock for perfect 90* corners every time. If he was not working on right angles just pull the bars out of the grooves and it was a normal table.
      Dan
    2. #22
      Atlanta, GA
      Quote Originally Posted by DRJDVM's '69
      I'm brand new to welding so as a first real project for my new welder, I was planning on building a welding/cutting table so I had a convienent place to do small welding and cutting jobs .
      Currently my only work bench is wood so I really need a good place to be able to set metal down and weld it or cut it. So far, I'm using a makeshift "bench" with some cinder blocks and a small piece of metal. Its definitely not very user friendly.
      In one of the welding books I looked at they had plans for a welding/cutting table. The rest of the book was worthless, so I didnt buy it.
      What I was hoping for is for some "real world" or "this worked great for me" or "I wish I had built it this way instead" advice....
      Nothing fancy, just practical....
      I asked the same question some time ago and received alot of good responses, alot of good information in the thread.
      Do a search for "quarterstang86" and look under the thread titled "Home built shop table, anyone built one? "
      For some reason I can't put an link a post. .
      - Richard
    3. #23
      La La Land, CA
