      St George Utah
      C5 IFS? wheel offset?
      Ok i have read the hardcore thread. i have purchased a front suspension geometry program to map everything out and confirm the geometry, but still need to confirm a couple things.
      the car is a 66 Beaumont with a Morrison Max G chassis with C5 IFS
      we are running 20" wheels with a OAD of 26.9 285/30/20 PS2 and 335/30/20 in the rear,
      WHAT is the Best Scrub radius to have ?
      right now i have a 245/35/20 with a 8" rim and 4.25 BS
      If i go to a 10" rim what Scrub radius should i want, i think 1" Negitive ?
      Jun 2005
      It'll never work
      Oct 2003
      Arvada, Co
      Are you trying to determain your scrub radius by your rim offset? What scrub is on the chassis now? If you bring the wheel in to close you may run into steering issues do to the rim hitting the frame.
      Brian
      Shell Beach, CA
      C5 Wheels
      Front = 17x8.5x56mm
      Rear=18x9.5x61mm
      Nick
