      New Jersey
      Exhaust help!!!!!!
      I dropped the 69 3 inches in the back with detroit springs. Now the rear casing hits the pipes and its just on the jacks! Heres the thing. I got the muffler all teh way back off. I wanan slide everything foward like 3 incehs so it wont hit anymore. I cant cut the pipe before the muffler and slide foward cause theres a bend like 1/2 inch before the inlet and i cant cut the pip after the muffler for the same reason! Just to brake in the rear i went to autozone and bought cheap pipes and cut them to make turndowns! How can i fix this!!!am i guna have to get new pipe from muffler back? Maybe shorter mufflers...i have no idea.
      1969 Camaro SS aka Jumpin Jack Flash
      World All Aluminum 427 and tko-600 attached to that
      http://www.cardomain.com/ride/2305230/1
      Jan 2003
      Arizona
      Really the best thing to do is to drive down to the local muffler shop and have them bend you up some pipes. Luckily, that's one of the last, reasonably affordable purchases left in the universe.
      ________________
      Steve Chryssos
      New Jersey
      hahaha ok gotcha, thanks and ill let you know how it goes
      Colorado
      Can you cut some length off of the inlet and outlet of the muffler itself?
      I had to do it with my 3 chamber Flowmasters to get them to fit.
      Brett
      New Jersey
      i took 3/4 of everything...the inlet, outlet, and both pipes before and after the muffler. juuussssst makes it.
