    Results 41 to 60 of 82
      Feb 2006
      Wisconsin
      I stoped at the shop this week and they are making good progress. The fenders doors and valance are down to bear metal and one fender was in primer. I am very happy I switched shops. They still need to strip and prime the shell and then they are going to hang all the sheet metal to see how it fits and to get my super 400 hood put on right before they go any farther. I can feel the excitment coming back for this project.
      1968 Firebird. Owed and operated since 1981. 455 5 speed 4 link mini-tubed ect.....
      looks great always had a soft spot for the firebirds
      Feb 2006
      Wisconsin
      Is this project cursed?
      Well progress has stoped for a while one of the guys working on my car just had to have his gall bladder removed and then he is getting married on May 20th and going on a 2 week honey moon. The guy I took the car way from sent me a message that he had a stoke after I moved the car. This is crazy. Maybe I should name the project King Tut. Hereis a link the curse of Tut http://www.tqnyc.org/NYC00112/curse.htm
      Metro Detroit
      Relax on this one. It still takes 3 months to 1 year for a car to be painted and sent back to you. Add another year for you to put it back together.
      Look at it this way, the bodyshop is just allowing the patch/primer/paint to set properly R.P.
      R.P.
      Feb 2006
      Wisconsin
      Quote Originally Posted by Roger Poirier
      R.P.
      I am not freaking out or anything. I just find it wierd that all this stuff is happening I bend over backwards to make it easy for the guys to work on my car and get them anything they need and yet the car still sits. I am becoming a whinner I won't post any more unless I have some good news.
      Feb 2006
      I will tell you from experience, if you do replace a panel and use filler over it. If you don't wait a pretty good while before you do your final blocking and paint application, the filler will shrink and you will be ale to see the line where the weld is after a few months. My GTO got a new quarter, it took like 3 months to get the car back from the time I took it to him. It was super slick when I got it back. After a few months, I began to be able to see where the weld line was if I looked at just the right angle. It has been painted now for about 16 years and hasn't gotten any worse. I guess we just didn't allow the filler to fully cure out before painting.
      Feb 2006
      Wisconsin
      Update on project "Jinx"
      I have not updated for a while. Not much going on to speak of. They found a lot of messed up body work under the messed up paint. The work on smoothing the car had to all be redone. Emblem holes where not welded shut but had bondo in them the gas tank door hole patch was only tacked in place and covered with bondo the trunk key hole had a piece of metal glued in and then covered and the job on smoothing the door handles was awful. I thank the stars above I did not let him have it any longer. Anyway all the messed up body work has been repaired and the doors and fenders have been primed and cut in. They have started on the shell but had o stop for a while because the "bread and butter" jobs started to poor in the door. I am finally getting caught up at work so I am going to bring the doors home and reinstall the glass and try to get the shaved door handle solenoids in and working. Wish me luck hopefully that’s not too screwed up. BTW the poor guy doing most of the body work on "Jinx" was just in the hospital again with a staff infection. What are the odds? So far the list of problems guys working on the car have had is up to 1 heart attack, 2 stroke, 3 gallbladder removed and 4 staff infection that truly almost killed the guy. The doc said if he would have waited 24 more hours to go to the emergency room he may not have made it.
      Feb 2006
      SoCal
      Isn't it strange how only body men get sick? And only when they get to your project? It seems that they are able to crank out 10 cars but when they get to yours all of a sudden everyone in the shop gets sick! Strange huh?!!!???:bsjerk:
      ***Under Construction***
      Build Update Link:
      Metro Detroit
      Keep the faith, it all turns all OK in the end!
      R.P.
      Feb 2006
      Wisconsin
      The 2nd body shop ended up getting too busy to finish the bird so I moved it to the 3rd and last shop this week. The new shop only does restorations and hot rods so I won’t be pushed aside by insurance work. It took 100 hours to repair the mess that the first guy left me but now that is all behind me. I happened to catch the new shop as they where just finishing a project and they were able to take my car before the schedule filled back up for the fall. Looks like they will be able to start on it right a way and since there is no really heavy body work left it might move along pretty well. He actually seemed excited to work on the car and likes the direction I am going with it since he is a hot rodder from way back. I have seen a lot of his work over the years and have had friend use him and they have all been very happy. Wish me luck 3rd time is the charm. Once I start to see some progress I will start posting pictures again.
      Amsterdam,The Netherlands
      Country Flag: Netherlands
      That's really good news!! Gives you some perspective and faith..
      Cliff
      1968 Firebird
      Feb 2006
      Wisconsin
      An update on the 68 Firebird
      The car did get painted and I took it home for some assembly. Right now its back at the shop to put on a steel 400 repo hood because the super 400 hood (Fiberglass)just would not fit / line up like I wanted it to. Any why here are a few pics.
      McKinney, TX
      Looking good and ready to go off roading
      89 Mustang "Box Wine"
      Feb 2006
      Wisconsin
      Quote Originally Posted by Z06killinSBF
      WOW tough crowd
      Kettering, OH
      [quote=Steve Firebird]Right now its back at the shop to put on a steel 400 repo hood because the super 400 hood (Fiberglass)just would not fit / line up like I wanted it to.[quote]
      It looks great, but why do you need a repro' 400 hood when it looks like you've got two originals hanging on the wall?
      Feb 2006
      Wisconsin
      [quote=Hammered][quote=Steve Firebird]Right now its back at the shop to put on a steel 400 repo hood because the super 400 hood (Fiberglass)just would not fit / line up like I wanted it to.
      You guys don't miss much!The green one is a GTO hood. The black one has a slight bow in it and by the time I paid the body shop to strip it ,weld up the emblem holes and get it into shape I figured I would have as much in it as the repo hood cost me. I also have some good memorys of the car when it was black and I think it is a awsome keep sake. You know like a picture or something.
      that turned out cool,i like the combo.
      Feb 2006
      Wisconsin
      WOW it been a while!
      So I thought i would throw an update. There has been some changes to the car since my last post. It now has speed tech upper and lower control arms and QA1 coil overs in front. I had it mini tubded and a G-Bar 4 link installed and picked up some new rims. I have to wire up the brake lights get the exhaust installed and them put the rest of the interior in it and i should be on the road again. Here are a few pictures.
      Jan 2007
      Port Orchard, WA
      Steve, I've been keeping an eye on your threads and I gotta say the car is looking great. Keep on sending pics.
      Maryville, TN
      Now that's a sweet ride! Nice work!
      Dan
      A.K.A: That bald guy
      Find me on Facebook or my personal website.
      - 67 Camaro: Current Project Car
