Thread: TKO 600 ?'s
10-06-2004 #1
- Aug 2004
- 345
TKO 600 ?'s
I remember seeing a picture that identified the three plugs on the side of the tranny. can someone point me back there, or identify them for me. also i remember seeing a neutral switch. how does this one work, i ask because i have wires in my painless kit that are identified as neutral switch and am wondering if this one on the tranny will work, or if i would be better off rigging one up on the clutch pedal. thanks
10-07-2004 #2
- Aug 2004
- Encinitas, CA
- 219
TKO switch ID
kman67RSSS-
Driver's side mid case - reverse light switch (two brass studs).
Driver's side tail shaft - neutral safety switch (wire harness with plug).
Passenger side - electric speedo pick up (black plug in).
On the neutral safety switch, if hooked up with your Painless wiring, the car should start only when the shift lever is in Neutral.
I hope this helps.Jeff Mortenson
10-07-2004 #3
- Aug 2004
- 345
thanks. that helps a lot
10-14-2004 #4
New to Pro-Touring
- Sep 2004
- Indianapolis, IN
- 5
TKO details, NSS install
Here's a tech write-up for using the servo switch as a neutral safety switch:
http://www.5speedtransmissions.com/n...fey_howto.html
That's a low-amp switch, so be sure to use a relay! Hopefully your Painless harness already has one.
Mike
