Thread: New Caltracs issue
03-06-2006 #1
New Caltracs issue
The round bar that connects the front and rear heim joints (torque link?) is touching the rivet on the bottom of the leaf springs that holds the multi leafs together, should I be concerned?
Should I gring some off the rivet head? If that doesnt give me enough clearance, would it be alright to remove the rivet and install a grade 8 carriage bolt, nut, and lock washer?
03-06-2006 #2Do you have a pic?
03-06-2006 #3can you move thelink toa lower hole on the brackets (front or rear)?
POLITICIANS & DIAPERS BOTH NEED TO BE CHANGED, AND FOR THE SAME REASON!
03-06-2006 #4Nancejd-I will post a pic tomorrow
gen3bu-Yes I can but I thought people on here suggested they had better traction by using the upper hole on the front mount (the rear is not adjustable)
03-06-2006 #5
- Aug 2004
- Honolulu, Hi
- 163
