      ls1 rear rotor specs
      If it's on here, I couldn't find it. Can anyone provide the max & min thickness specs for a ls1 rear rotor? Are lt1 the same? I'm trying a home brew of brake parts. Thanks!
      Nov 2004
      Dallas Texas
      ls1 rear
      Rear Brakes
      Discard Thickness = 24.51 mm (0.965 inch)
      Maximum Lateral Runout 0.15 mm (0.006 inch)
      Minimum Wear Thickness = 24.89 mm (0.980 inch)
      Rotor Thickness (New)= 25.90 mm (1.020 inch)
      Minimum Thickness After Refinish= 24.89 mm (0.980 inch)
      LS1 and LT are different LS are bigger- and thicker
      Thanks for the response! Unfortunately it seems that ls1 rotors may not work for me. I need something that is 12.8 x 0.78 with 5 on 4.75" bolt circle or as close as possible.
      Did you find that information online somewhere? I couldn't find anything that specific using google.
