      Mar 2003
      Fallston, MD
      help me identify these plugs
      This is a 98 ls1 harness I would like to know what these plugs are
      Brian Schein
      Maryland
      Hey Brian,I've done 5 or 6 LS1 harnesses now,most of them 98's.the first picture plugs I know get eliminated,the others I have the GM plug identification and color code diagrams,but I can't make them out from the pictures
      Mar 2003
      Fallston, MD
      Do you have this plug identification diagram in an electronic format or is it on paper. Id like to get a copy of this. I am putting a complete 98 body and engine harness in my car. I want to make all the factory systems work. The only thing I an not worried about hooking up is the abs system.
      Brian Schein
      absecon, new jersey
      Brian i have any wiring diagrams you need i can print them off my snapon shop key from work if you want and mail them to you,i cant email them the program wont let me.Let me know if you want me to print them out.I took my 99 fbody harness and modified it to work for me.
      "[email protected]" is my work email send me your address if you want me to send them to you.
      73 corvette chop top silver LS6 motor ,LS6 intake,700r4,2400 pro torque convertor ,3.70 gears,modified hooker sidepipes to fit LS1,17 x9.5 boyd starburst,nitto 275/50/17-255/50/17 tires,vb&p suspension,nitrous,L-88 headlights,autometer guages.L88 hood,flares,spreader bar,vb&p sway bars
      Apr 2003
      Nyköping, Sweden
      Country Flag: Sweden
      The last image shows the plugs that connects to the rest of the car. The round one go from the starter solenoid to the ignition key over a relay.
      The other two are among others to the electric radiator fans (controlled by the ECM) and to the fuel pump. Both over relays. Somewhere there is also a connection to the diagnostic bus.
      If you get the wiring diagram you should be able to figure it out.
      Jan
      Jan Suhr
      Nyköping, Sweden
      1969 Pro touring Camaro Z/28 LS1/T56
      Scandinavian Pro Touring Forum protouring.se
