    Results 1 to 11 of 11
      Feb 2006
      Brake upgrades 78 t/a
      OK, now onto brakes ... you probably know this from other forums, but just in case - I'm working on upgrading my 78 t/a. This is primarily, if not entirely, for street use. I just want a good-performing/handling setup.
      Right now my car has disc fronts and drum rears. Now I'm debating what to do. Given advances in technology and the fact that it sat in a lot for 7 years and is now 28 years old, I was thinking I should change out all the brakes. I figure my options are:
      1) Look at my existing parts and just replace anything that looks suspicious.
      2) Put in a new disc brake kit in the front, but leave the rear drums.
      3) Put in new brake kits front&rear.
      My inclination is to at least do option 2), but if option 1) is sufficient, I'm all for saving money! As for option 3), how much benefit will I get since 70% of the braking comes from the front anyway?
      Since it would cover all the necessary pieces, let's say I choose option 3).
      I was thinking of getting the Wilwood Dynalite Pro Series kit. It seems people generally like the Wilwoods, though others like Baer, and in this thread, Mean 69 says he thinks all of the kits are crap and you should just search the "Cheap Big Brakes" threads and follow those directions.
      http://69.94.75.177/forum/showthread.php?t=5130
      Though he does say he has more of a racing bent and that might be biasing things.
      Now if I upgrade the rear drums to discs, the only kit I was able to find was the SSBC. LTorres (Precision Brakes) made reference to wilwood rear disc kits in a couple threads, but looking at the precision brake catalog online, I couldn't find any for 2nd gens. Did I miss them?
      What additional things might I need? My guess is I'll need a proportioning valve. Do I need that if I just put a front brake kit in and leave the rear as drums?
      And finally, I saw mention in a couple threads of the various brake kits affecting wheel backspacing. Good thing I saw that now, since I was just about to order wheels!
      With the Wilwood kit mentioned above and the SSBC kit listed below, will I have any backspacing issues?
      http://store.summitracing.com/defaul...+-59338+-42236
      I was going to get TT-II's (even though they're "over-done") with 17x9.5 5.5" backspacing upfront and 17x11 5.75" backspacing in the rear. In case it's relevant, I was thinking of either 315/35/17's in the rear and 275/40/17's upfront or 285/40/17's in the rear and 255/40/17's upfront.
      Sorry for the length! And thanks for all your help.
