      Caltracs problem
      The aluminum front bushing that they provided are to small O.D. like a 1/4" what to do?
      I told them that I had hotchkis springs when I ordered the kit and I just sprayed the white rancho shocks black.
      Auburn, WA
      Did you call them and ask? Seriously, that should be your very first step.
      If they don't want to fix it, just make a new bushing (or ask a machine shop with a lathe). Make the ID and length the same, but make the OD to what your spring is (Sometimes they are a slight press fit, maybe .001" oversize).
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Santa Barbara, Ca
      I also have Hotchkis springs and Caltracs. My bushings fit the front spring eye perfectly. I took off the springs and pressed the bushings on a hydraulic press at work. They were a tight fit, using a press was needed. Are you saying the bushings are loose in the spring eye? The Hotchkis springs should accept a standard 1st gen sized bushing. Maybe Calvert sent you the wrong ones?
      -Andy
      They sent the wrong bushings, instead of 2" they sent 1.5", they sent the correct bushings 2nd day air. I received them and had them pressed in.
      I just finished the install and I am psyched! I hope like hell my wheelhop is gone; however, I wont know till my ZZ383 gets here.
      Thanks for the replies.
      Nov 2004
      Roanoke, VA
      Quote Originally Posted by ertoys
      Calvert Racing is one of the places I really enjoy doing business with and they seem to genuinely strive to satisfy their customers. I was mistakenly sent the wrong front spring eye bushings as well and after a phone call to calvert I had the correct ones in my hands in a couple days.
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
      Feb 2006
      Elk Ridge, Utah
      Kiss it goodby
      Hehe Your Wheelhop is a thing of the past. I had a 69 with a 496 BB solid roller motor in it w 10's in the back it Wheelhoed so bad it broke axles and the th400 next. i put Slidealinks on it and Bye bye wheelhop traction improved too but still didnt Hook. =) That car sold New one being built =)
      Gl Ken
      Caltracs are now installed, question.
      The round bar that connects the front and rear heim joints is touching the rivet on the bottom of the leaf springs that holds the multi leafs together, should I be concerned?
      Should I gring some off the rivet head?
