      Santa Barbara, Ca
      Core support bushings
      Is it ok to use solid bushings to mount the radiator support to the frame on a 1st gen? I plan to use GW's bushings to mount the sub to the body, but I thought I remembered reading somewhere that using them on the core support was a bad idea. Is this true, or am I imagining things again?
      -Andy
      IL/TN
      I would not worry about it the rad. should be mounted on it's own rubber pads, look at a modern unibody car the core support is part of the car structure,FYI same gose for poeple that think solid body bushings will give a harsh ride.
      https://www.protouringf-body.com "doing what they say can't be done"
