      Aug 2003
      Prescott Valley, AZ
      what's the difference?
      Does anyone know the weight difference between a big block chevy iron head and a small block chevy aluminum head? I’m thinking about swapping to save some weight.
      It's shake and bake!!! and i helped!
      Drewco Homes
      dennis68 Guest
      B/B iron to S/B al head is at least 200lbs. Heads alone are 75lbs. Then you have the LS1 swap, that is another 150lbs. off the front clip.
      Here are exact figures:SMALL BLOCK
      all iron small block 520 lbs.
      alum heads w/iron small block 480 lbs.
      all alum motor 389 lbs.
      BIG BLOCK
      all iron BB 754 lbs.
      alum heads with iron block 660 lbs.
      all alum BB 501 lbs.
      So, B/B iron head to S/b al head difference is 274lbs.
      Aug 2003
      Prescott Valley, AZ
      soooooo
      What I’m reading is if I swapped to an ls1, I’d shave off 365 lbs?
      Holy Hell!!!
      Drewco Homes
      dennis68 Guest
      Guess you have a new project. Don't forget when you are fabbing mounts you might as well set the motor back a few inches for some more weight distribution advantages.
