    Thread: front too high
      front too high
      i installed DSE drop leafs and now that i have hung the front sheetmetal the front end is too high. i was thinking about cutting down the coil to get a little lower. is this a bad idea, or is it safe. main reason im thinking about this is because its free and i could use the money wiser elsewhere.
      Jan 2004
      NW Suburbs, Chicago
      unless its a progressive rate spring it should be ok...
      Oct 2003
      Arvada, Co
      Yes cutting the spring will be ok. Just cut a little at a time with a cut off wheel not a torch.
      Brian
      Jul 2002
      Muskegon, MI
      Are they the original front coils? The reason I ask is if they are new will settle after about 100-200 miles. Otherwise you will be fine cutting the coils.
      they are the original front coils to my knowledge. maybee i will wait and see what happens
