    Results 1 to 9 of 9
      Scottsdale AZ
      Best chassis paint
      What is the best chassis paint out of a spray can?
      I tried POR15 and did not like the way it laid out (more for floors I think).
      The Eastwood Chassis Black was not bad.
      I don't have the cash to have it powder coated.
      Any ideas?
      Feb 2006
      Enumclaw, WA
      I'm having my frame powder coated for $200. How much did you get told it would be?
      Jason
      San Diego, CA
      damn I was quoted at $450 2 months ago, and $300 this past week...
      $200 including blasting?
      Oct 2005
      Granger,IN
      I have a friend that powdercoats frames in Nappanee IN.
      I no idea what he charges now but I can find out if you are interested.
      Sandblasting is a big factor in the cost. But even without sandblasting I can't imagine it is could be as cheap as $200, That sounds too good of a deal to be true. There is a large variety of powders that vary significanly in cost and quality, Many powders are not UV stable so they should have a UV blocking clear powder on top of the color powder. At my work all of our steel fabriccators have switched to powdercoating and the quality of the coating is worse than old fashioned paint. Ask a LOT of questions.
      - How thick is the powder?
      - How much coverage will there be? (powder \doesn't like to go into deep crevices
      - What type of powder?
      - Is the powder UV stable?
      - Will there be a clearcoat on top.
      - Is sandbalsting included?
      - Will the frame be dipped into etching wash before coating?
      Another option is E-coating, its a full dip in a paint bath so it is great for frames. There are several places in the Elkhart Indiana that do that. E-coating is more porous so it can be better if you are applying a top coat. With powdercoat you better scuff every square inch of the coating or the top paint can falk off. Ecoating should still be scuffed but it is not as critical.
      Free hostings of solid models!
      http://www.wrenchmonkey.com/Webpages/Solids/Solids.html
      92 Stealth Twin Turbo with 3.5L Engine swap
      Looking for my next project, maybe an AWD 71 Lemans????
      Apr 2004
      OKC, OK
      I had an entire Blazer frame and suspension powdercoated for $250. Sandblasting was another $175. There is no way I could buy the paint and do it myself for that.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Nov 2004
      NW Arkansas
      we use base/clear never been a fan of powder coated frames.....can't do any bodywork on them and never match when done in a body color
      KENNY DAVIS HOTRODS
      Feb 2006
      Enumclaw, WA
      The $200 was for powder coating only. My cousin had his Super Comp dragster frame, 9 in gousing and some other misc parts done for $400 and turned out beautiful.
      Jason
      Oct 2005
      Granger,IN
      I double checked with my buddy in Napanee IN:
      He normally charges $250 for a single layer of standard powdercoating, clearcloats, heat resistant coat, and other special powders cost extra.
      Sandblasting is extra, he can arrange to have it done if you drop the chassis off with him. On average the toal come to $500 for sandblasting and powedercoating a full frame.
      Granger , IN
      I just did the front sub frames and complete underside of the cars on 2 69 camaros im doing and i used PPG DP90 Epoxy . 2 coats.
      i didnt care for POR15 either but had good luck with the Black DP 90
      Its tuff and you can do any body work needed first and its durable and cheaper than powdercoating ..Just a option.
      It has a Satin / semi gloss look to it and wipes clean with no staining.
      I can post a picture or come loo at it if you close enough.
      Jeff
      Hey John . i sent you a PM...heres pics of a few of my cars and one of my 69 Pontiac.
      The Voices in my head tell me i need more cars
